LS/VTEC (B18C1/B18B1) hybrid. Can this take turbocharging to about 300whp? Answer-Yes
I have a bone stock b18b1 with a gsr head that I bought to put in my 95 civic coup. Will this motor bone stock handle boost maybe around 8 to 10 psi with out frying the motor
Yea just have it tuned properly!, make sure you have a oil temp sensor and a AFR gauge to view inside to keep an eye on those things while driving. Don't beet the crap out the engine and it will last as long as you keep it maintained. But it doesn't mean you wont wear out the engine faster cause you will, the rings will wear out faster depending on how healthy the engine is, Makes sure you got good compression numbers at least before boosting it.
I went a head and orders Brian crower stage 2 turbo cams with springs and retainer cp forged pistons and eagle rods and rod bearing also order ferrea 6000 turbo valves. I have arp head studs with golden eagle head gasket what bolts should I use for the cam guard, can’t find arp bolts for it
I went a head and orders Brian crower stage 2 turbo cams with springs and retainer cp forged positions and eagle rods and rod bearing also order ferrea 6000 turbo valves. I have arp head studs with golden eagle head gasket what bolts should I use for the cam guard, can’t find arp bolts for it
I threw up in my mouth a bit there. But....Moving on. Just stick with OEM GS-Rs for now, if you're going to do that..
Pretty obvious we're saying that about the camshafts. Quality control, Specification numbers aren't correct. People look at the buzzwords of "STAGE2" and "TURBO" and just think... OMG this is gonna be awesome!! When, they just bought something that really isn't going to be much better than a GS-R or CTR camshaft.
I didn’t order the cam because they said stage 2. This is my first build and me and why wife are doing it together. I been getting advice from a lot of people and I was told I would be good to run a turbo cam so as I was looking I came across a good deal and took it.
Next time, (if there is one) list your whole potential build before you start running the credit card..
I guess.... You know, what you know. .
^^ Yup.. My credit card companies LOVE me right now for all the mistakes I made. Lol!
OP.
As mentioned, GSR, CTR, or even Skunk2 pro1.. Good cam choices there. But, you bought what you bought. It's your build, buddy! Still looking forward to seeing the results here. It's cool the missus is getting in on it too, quality time!!
OP.
Yeah I’m still learning as I go we all have to start somewhere. I was just making sure I have good stuff while I have the motor on the stand I want a strong healthy motor
I’m confused, you asked about a stock motor being turboed then order a butt load of parts before anyone could reply
Yes I was asking about the motor being stock and boosting it but I took it a part to double check everything because I bought it from a guy who put it together and started to see that it looked like it had high mileage on the pistons and cams I also talk to a few people around town and they gave me advice on what kinda stuff I should run
You do have a point there and I appreciate your opinion next time I will do more research and ask more questions
‘[sic]...I’m a serious do it yourself type person, but I asked a ton of questions before I started buying stuff..... locals opinions seem centered around their personal preference most of the time and not always what’s best for you. I’ve got the same motor you have and I’m setting close to 700whp now for a reason
For every project I've assisted with and built, the 1st question I always ask is....... what's YOUR purpose for the car?... Not the locals...not your cousin's..... YOURS..
Eg_mE
13
Dec 24, 2008 05:00 PM
ls95hatch
15
Apr 10, 2004 06:58 PM
