The kit allows:
- conversion ignition system into multiple coils
- making bigger gap on spark plug, without risk of misfire
- in case of tuning- allows to setup earlier ignition, that can increse engine power
Advantages of conversion:
- very strong and precise ignition spark in all range of engine RPM, thanks to application individual coils and omitting distributor and cables
- inrease engine reliability with removal of failuring elements such as distributor rotor, cap and cables
- if one of cois fail during exploatation, it does not stop engine runing, as it goes in theoriginal ignition system
- engine power increase even 10 % without tuning in N/A and even more in boosted
- increased resistance to engine knocking
- decreased and more efficent combastion
Features:
- easy instalation without soldering and professional tools, just replace stock coil by kit module
- it does not change engine control paramters
- module is protected against humidity and vibration
The kit works with:
- all Honda engines with distributors in shape of OBD1/OBD2b
- ECU or ECU OBD type does not metter
- support coils from D-series and K-series (30520-PVF-A01, 30520-PNA-007)
The modification kit consist of module and wiring, to run this kit you only need are coils.149USD + shipping
shipping to US 49USD
