1992 Honda Civic Manual Transmission Problems Diagnosis
Old Nov 10, 2019 | 09:06 AM
SSOARES's Avatar
Default 1992 Honda Civic Manual Transmission Problems Diagnosis
I was on my way home and stopped at a light. When trying to get the car going again
I heard a loud mechanical "pop" and the engine spun but the car wouldn't move. I
pulled it out of the way and tried to get it going - no luck - the tach registers rpm,
the engine runs but won't engage the transmission. The clutch plate and flywheel
are less than 3-yrs old. The throw out bearing is the original one. The clutch slave
cylinder is more than 5-years old.
Any suggestions - THANKS MUCH
Old Nov 10, 2019 | 03:10 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: 1992 Honda Civic Manual Transmission Problems Diagnosis
Tranny will have to be pulled and tested to see where the issue lies.
Old Nov 10, 2019 | 08:50 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
First guess is axle popped out of tranny? Explains why it wouldn't go anywhere (open diff).
Old Nov 11, 2019 | 04:07 AM
mk378's Avatar
Does the speedometer go up when you try to move? If it does the transmission is working, the problem would be axle-related.
Old Nov 13, 2019 | 01:58 PM
muellersfan's Avatar
Or the axle broke.
Old Nov 15, 2019 | 12:36 PM
DaX's Avatar
DaX
Loved
Community Favorite
You can pull the access plate by the oil pan and see if there is a bunch of clutch material piled up under the flywheel. If the clutch is of poor quality or if it gets oil soaked, it can come apart. Just another thought as to what it could be.
Alicali
Nov 26, 2016 05:26 PM
uindaway
Transmission & Drivetrain
Nov 20, 2012 10:38 AM
Devers
Oct 31, 2011 04:55 PM
WestSideRain
Dec 31, 2010 05:40 PM
