D17A2 Spun bearing
Old Nov 10, 2019 | 03:17 AM
freshwateriow's Avatar
Default D17A2 Spun bearing
My daughter has a 2006 1.7 V-TEC FRV. It had a spun bearing (at the cam belt end) which after cleaning up and checking the big end journal was within spec. We replaced all the shell bearings and ran up the engine and heard the familiar knocking. I removed the the big end cap and the bearing had not spun but was starting to wear and had oil but a lot less than the bearing at the flywheel end. I have blown air from a foot pump and that comes out at the main bearing, but cannot check the oil pump side is there a way of checking the oil ways in the crankshaft. Is there a diagram of the oil flow through the crank and engine? Any help would be appreciated. Cheers Dave S
Old Nov 10, 2019 | 09:03 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: D17A2 Spun bearing
If I remember right, people always say to use a pipe cleaner on on the oil holes in the journals. I personally have not seen the oil pathway being illustrated in the FSM but I somehow could have missed it.
blkrex
Oct 4, 2006 09:23 AM
94-integra-ls
May 8, 2006 03:37 PM
spooledhonda
Mar 9, 2006 03:17 PM
jvtec95
May 22, 2005 03:33 PM
dustin
Oct 23, 2002 12:06 PM
