ATTN: those with puck style clutches, specifically ACT
Old Nov 14, 2002 | 09:22 PM
93 VTEC's Avatar
Default ATTN: those with puck style clutches, specifically ACT
Do you notice alot of chatter/harsh engagement? I have a 93 Prelude with an ACT 6 puck unsprung and unless I am concentrating on being smooth I get mad chatter. Does anyone else have this problem? I knew it would be harsh but I was hoping it wouldnt be this bad. Even between gears it is hard to be smooth.
Old Nov 14, 2002 | 09:55 PM
B20zvtecek's Avatar
Default Re: ATTN: those with puck style clutches, specifically ACT (93VTEC)
Did u Re-Surface your flywheel?
Old Nov 14, 2002 | 10:39 PM
Norcalstoppy's Avatar
Default Re: ATTN: those with puck style clutches, specifically ACT (B20zvtecek)
RK just got a clutchmaster stage 4 with 4 puck clutch and it chatters if he doesn't rev it up a little.
Just rev it up a little higher than normal.
Jay Kim
Old Nov 14, 2002 | 10:59 PM
turbologist's Avatar
It all depends on how u drive it. I have it and I had my flywheel resurfaced and like it was stated earlier u have to rev it a little when u take off from a start. If you do that and ease off the clutch u shouldnt have any chatter. It just takes some time to get used to. Dont worry you'll get that hang of it soon..
Old Nov 15, 2002 | 01:06 AM
Benj's Avatar
Default Re: ATTN: those with puck style clutches, specifically ACT (drealboostedhybrid)
I have an Exedy 3-puck clutch. Had that same problem when I was new to it. Don't worry you will get used to it. You just have to be smooth in letting go of the clutch. Drive the car everyday for a few weeks, you should get the hang of it soon.
Old Nov 15, 2002 | 06:40 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: ATTN: those with puck style clutches, specifically ACT (Benj)
Probably because it's a 6-puck unsprung clutch w/ basically on/off engagment. Mainly for race use only. I'd never wanna drive one again on the street.
Old Nov 15, 2002 | 08:02 AM
gsrvx's Avatar
New User
Default Re: ATTN: those with puck style clutches, specifically ACT (AllMotorMonster)
Jay Kim
Old Nov 15, 2002 | 08:58 AM
Kataku2K3's Avatar
Default Re: ATTN: those with puck style clutches, specifically ACT (RK)
They will chatter.... I like 6 puck the best even with a little chatter.. My friend has an ACT Maxx Xtreme pressure plate with a 4 puck disk on his GSR/EK.. If you don't rev it up a bit it will chatter like crazy.... It's just something that you get from a solid disk..
Old Nov 16, 2002 | 05:53 AM
93 VTEC's Avatar
Default Re: ATTN: those with puck style clutches, specifically ACT (JDMspecEG6)
I am used to it, I have had it for about 6 months now. I just pulled the motor for a rebuild and I was considering using a street dick when it goes back together. I was hoping that maybe there was something wrong with my clutch and that no one else had any problems with a 6/4 puck. Oh well, I guess I will keep my chatter.
LukieLuc
Jun 24, 2007 10:37 AM
preludetospeed
Apr 6, 2007 07:16 AM
reset2k
Apr 12, 2006 05:15 PM
allstockb18c
Jul 3, 2005 12:44 PM
2k1 SSM GSR
Jul 9, 2004 01:46 PM
