91 DA trans (manual) in a 98 DC shell.
Old Nov 6, 2019 | 07:15 PM
khamaryn's Avatar
Default 91 DA trans (manual) in a 98 DC shell.
Does anyone know if a 91 B18A cable trans will mount into a a 98 DC shell with no modifications? Would I use DA mounts on the DC shell?
Old Nov 7, 2019 | 07:06 AM
1stGENGSR's Avatar
Default Re: 91 DA trans (manual) in a 98 DC shell.
The DA mount would be needed for the passenger side, and you’d have to do a hydro to cable conversion... It would make more sense or (at the very least) be cheaper to open the cases up and swap over the internals into your hydro case, provided it is in fact a YS1 LS transmission and not a jdm or other foreign one with the slightly smaller shafts. I recently swapped s4c internals into one of my ys1 cases and it’s fairly easy. I also put the old ys1 internals into the s4c case for safe keeping (it’s a direct swap either way with no modding needed), as I’ve got to replace the synchros on that gearset sooner or later.
hatchet_honda
Mar 30, 2011 05:58 AM
jnagel12006
Sep 21, 2008 02:14 PM
spideymangDC4
Mar 1, 2007 06:49 AM
unclecaveman
Nov 8, 2006 02:51 PM
94B18Civ
Oct 12, 2005 12:35 PM
