Question about Axles and Axle seals.
Old Nov 6, 2019 | 10:35 AM
mikecp's Avatar
Default Question about Axles and Axle seals.
Hey guys, I got that clicking noise on the passenger side of my '97 DX. Also, i notice oil spots when I park the car coming from right above the axle so that leads me to believe the seal is going bad as well.
My question is this, I'm going to replace both the driver and passenger side axles, does the driver side have a seal i should replace as well? And is part #15 correct below?
Old Nov 6, 2019 | 12:20 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Question about Axles and Axle seals.
Yes, Part #15 in the diagram is the passenger axle seal. Yes, replace the driver's seal while you're at it. Be careful to not damage the new seals when installing them.
Old Nov 6, 2019 | 12:53 PM
mikecp's Avatar
Thanks for the info. Is the driver's seal the same one as the passenger? Or are there two different ones?
Edit - is the driver side one #6 in this diagram?
Old Nov 6, 2019 | 02:25 PM
DaX's Avatar
DaX
Loved
Community Favorite
Yep, #6 in that diagram. Different part numbers.
Old Nov 6, 2019 | 04:45 PM
collinkuhn1's Avatar
Yes make sure you get the right seals. They are not the same size. The inner diameter of the seal is the same but one side has a larger outer diameter
Old Nov 6, 2019 | 07:28 PM
chrysler kid's Avatar
Order oem ones, the aftermarket ones sometimes lack the dust sleeve on them to prevent debris from flying up into the gap between the cv axle and trans
Old Nov 7, 2019 | 07:50 AM
mikecp's Avatar
Thank you for all your help guys - I've ordered both from hondapartsnow.com so I should be good to go.
thanks again
onsetofpurity
Dec 2, 2009 09:35 PM
I CRX I
May 7, 2007 07:23 PM
ivan1985
Nov 2, 2006 01:10 AM
EG2Driver
Oct 25, 2006 05:42 PM
Revolution2zz
May 13, 2004 08:45 PM
