2000 civic z6 swapped p28 harness no spark
Old Nov 3, 2019 | 03:50 PM
Dylan Faw's Avatar
Default 2000 civic z6 swapped p28 harness no spark
I've read alot of post on this site . Lots of good info. I have a 2000 civic y7 motor pulled. I have a p28 auto to man conv ecu . And 95 z6. I put the engine in, left the z6 alone and used an ecu adapter ,and the 2000 harness. Obviously a few left over plugs , had to change the injector harnesses , iac and VTEC connected and oil switch. Just so they would plug in. . I've wire the dizzy up correctly as far as I can tell. Checked all the grounds. Known running motor different ECE(matching numbers). My question is could one of those lugs need to have a ground ? Not getting spark. Known rini g motor distributor everything. I just tried to use my harness to hook up stock computer/stock motor
biff206
42
Nov 5, 2013 02:54 AM
eoris__ej1
May 15, 2013 06:17 AM
luv_EF
Oct 12, 2011 11:55 AM
DxBurnoutKing
50
Apr 22, 2005 05:36 AM
