transmiision filter
It is inside the case, you would need to remove the trans and then open the case to access the strainer.
It is not a readily accessible component.
This is why it is critical to drain and refill the trans at the determined intervals, as the strainer can become impacted with debris and become blocked, rendering the trans starved of fluid and non-functional.
wkdclwnz
Sep 26, 2006 03:56 PM
bluefuse
Jun 29, 2006 09:52 AM
Overmind22
Mar 28, 2004 09:47 AM
