Ef b swap help
So it is a small question amd hoping someone can help , ive already got the motor in and everything , now my question is what shift cable and throttle cable do I use ? Can i use the stock or do I have to get it from an integra ? I threw in a b18a1 with a cable tranny
you can use the stock throttle cable but you have to order or make your own bracket
the one that connects to the intake mainfold
and the cable for your clutch you can also use the factory clutch cable
i dont know what kind of clutch cable you have
but on my 4dr i used a crx si clutch cable
hope this helps
hope this helps
I got a da throttle cable out the junk , but someone already took all the shift cables. I fitted the stock one to fit, but it feels really stiff and if I loosen it , it has some play in it
4gencivicef9
Apr 9, 2006 07:18 PM
CRexcellence
Dec 11, 2002 03:12 AM
