d15 wont start
recently swapped my blown d15 for another d15 car is turboed and havent been able to get it to start bought a brand new dizzy seeing i was told i had weak spark an still even with the brand new dizzy still no start doesnt even try to fire with starter fluid any info or ideas would help thanks.
Air/fuel/spark/combustion/timing
should be diagnosed somewhat in that order.
looks Like you’ve done some diagnostics. I’d check all grounds. Check all fuses. If it’s still not starting with starting fluid then it’s possibly a spark issue. Or since it’s a new engine it could have no/low compression. Can be a multitude of things being a fresh engine swap.
Fishingguy1973
Jan 10, 2012 08:46 PM
solk1dd
15
Feb 7, 2005 01:50 PM
