Engine Swap Help!
Old Nov 2, 2019 | 11:15 AM
Ri Kunstman's Avatar
Default Engine Swap Help!
I知 planning on doing a j32a2 engine swap on my 01 Accord EX Sedan (V6,3.0). Also going to try to swap it from automatic to manual.
So I知 basically just wondering what I壇 all need besides the engine, transmission and clutch?
Old Nov 7, 2019 | 09:27 PM
Stevo1018's Avatar
Default Re: Engine Swap Help!
You Need A Peddle To Start With, Peddle Switch, Mounting Brackets, Pressure Plate, Shift Linkage, Etc. its alot more work then people think it is
Old Nov 7, 2019 | 09:30 PM
Stevo1018's Avatar
I just did a a4 swap on a f22b2. Im dealing with it not starting. Code 15. which is no spark or somewhere in that area. Distributor, Coil pack, Main relay. etc. I Swaooed out the whole head an ran everything right but i dont know if i have to change out the whole distributor, ECU swap from obd1 to obd2, Im stuck right now, have spent more then enough already
civic racer99
Mar 29, 2009 05:15 AM
ptsiu
Dec 9, 2002 03:08 AM
