crank no start
Old Nov 1, 2019 | 05:23 PM
needdx's Avatar
Default crank no start
1990 civic dx voltage on blk yellow to ground at distributor no voltage on wht blue wire at distributor with ignition on
Old Nov 4, 2019 | 08:11 AM
4drEF's Avatar
Keyboard Humorist
Default Re: crank no start
wht/blu wire should be ground so that's good there isn't any voltage on it.
Small white and blu/yel are also grounds.
You said DX, but it seems you have a swap, right?
DPFI distributor (found on the DX) does not have a blk/yel or a wht/blu.
Old Nov 4, 2019 | 10:52 AM
needdx's Avatar
Hey 4dEF thanks for the reply,I do know that's its not the original engine, how ever on the 2 pin & 5 pin plugs at the distributor I had 12V to ground on both wires wht blu & blk yel this according to haynes manual I'm using, in addition I changed the ignition switch after changing the distributor # 1 on # 2 now
Old Nov 4, 2019 | 12:28 PM
jlicrx's Avatar
do you have any codes showing on the ECU?
Old Nov 4, 2019 | 02:58 PM
needdx's Avatar
Gentleman replacing the igniter solved my problem earlier in year,but this last fail I decided to change the entire distributor, there are no trouble codes also I have no idea what a A/T control unit is??? I'd like to know on mechanical side of the ignition switch is there contacts involved when switching the positions Acc I II &III
Old Nov 4, 2019 | 03:19 PM
4drEF's Avatar
Keyboard Humorist
A/T = "Automatic Transmission control unit"
needdx
Nov 1, 2019 04:45 PM
TPersaud
Feb 17, 2019 04:40 AM
89hondacivicdx
13
Sep 17, 2011 05:43 PM
jweezy225
Jul 26, 2004 04:11 PM
CRX7
Mar 5, 2002 08:21 AM
