Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Water dripping onto passenger side floor mat
Old Nov 1, 2019 | 09:41 AM
wetfeet's Avatar
Default Water dripping onto passenger side floor mat
2012 Accord sedan. Driving to work this morning, after heavy rains overnight, I noticed the sound of water sloshing behind the passenger dash (glove-box-ish area) every time i made a left turn. Once I got to work I noticed water had started dribbling out onto the passenger floor mat. I had a coworker pop the cowl up a bit to look for a clog, but the rain water reservoir wasn't even wet. They couldn't find a clog or even water, yet when I moved my car in the parking lot I could still hear sloshing and a fair amount of water dribbled out onto the floor mat again. The weather is changing fast and will be freezing soon, I'm worried that a large mass of water is sitting somewhere in my car and will freeze and damage something important. Does anyone have any thoughts on where the water might be and/or how i can remove it before it starts freezing? Any ideas are appreciated, thank you.
Old Nov 1, 2019 | 11:41 AM
hondafanornot's Avatar
Default Re: Water dripping onto passenger side floor mat
do you have sunroof? is it wet from head to your toes/feet?
find the source by drying the floor first, then put small pieces of paper about 10 inches apart, whichever wet first, that's the source. i hope that help
Old Nov 1, 2019 | 11:44 AM
wetfeet's Avatar
I do not, it is a simple base model accord. The water drips from a piece of molded plastic that appears to be a fan cover right at the back of the dash on the passenger side (right above where one might rest their feet).
Old Nov 6, 2019 | 07:55 PM
Hidenplanvew's Avatar
You sure its not coolant? possible drain for the ac evap core is clogged. its behind the motor on the bottom side of body. right behind the subframe and should be on the passenger side. Use compressed air to clear the hose out.
Jafatz
Nov 8, 2021 05:53 AM
Shanvhere
Honda Civic (2006 - 2015)
Sep 18, 2019 12:55 PM
93dateggy
Jan 16, 2009 12:03 PM
Mayorseed
Nov 1, 2007 04:51 AM
Kelvin96GSR
Nov 29, 2001 10:48 AM
