Classic Hondas All Pre-1988 Hondas.
Honda s800 coupe 1968
Old Nov 1, 2019 | 04:16 AM
alfro04's Avatar
Default Honda s800 coupe 1968
Hi
i got a question for you regarding a project s800 mk2 that iam busy. Mk2 carb set.
I got the car from Germany to restore and found out that the engine was not firing the n 2 spark plug.
There is spark, compression in this particular one 8 k, the others 9 and above, valve gaps ok, 0.2mm to 0.4mm in all of them, and no firing, tried a different set of cables, other distributor, tried also mk1 carbs that is running on a mk1 car that i have, still no firing.
I think the engine was serviced there in Germany before i got it by the looks of the fresh oil in, but oil filter not replaced and full of mud.
This is a late engine.
So decide open up the engine, and reassembly it...did the valves, skim the head, put new rings, new gaskets etc...compression now better, valves gap between 0,2mm to 0,3mm.
Start the engine the original problem still remains...
Any tips would be appreciated,
Thanks
Alf
__________________
Regs AR
Old Nov 4, 2019 | 12:59 AM
alfro04's Avatar
Default Re: Honda s800 coupe 1968
sorted thanks
Old Oct 25, 2021 | 02:07 AM
Len1's Avatar
Hi My Honda S800 is doing the exact same and I have tried everything you have tried. Did you find out what the problem is ?
thanks
Old Nov 7, 2025 | 06:40 AM
luhos800's Avatar
Hello, I have the same problem. 4 small carburetors, model MK1. The accelerator pump is missing. The car started and after a year of standing - I did other things on it - it doesn't want to start.
Please tell me how you solved it.
Thank you very much.
lubom1@centrum.sk
Mistr Theodorik
Nov 4, 2017 11:48 AM
HondaGirl8
Honda Civic (2001 - 2005)
Aug 15, 2014 05:52 PM
kingmickez25
11
Jul 14, 2012 01:31 PM
ice2004
Jun 1, 2008 09:53 AM
