Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2003 03 Odyssey Water Leaking Under Passenger Side Front Carpet
Old Oct 29, 2019 | 06:52 AM
Jafatz's Avatar
Default 2003 03 Odyssey Water Leaking Under Passenger Side Front Carpet
I have water leaking under the front carpeting on the passenger side near the door when it rains.
When I lifted off the sill cover and peeled back the carpet it appears to be coming from underneath a rubber lining the runs under the lower dash behind the glove box and heater/AC box and fan assembly.
When I removed the fan and felt inside I could not find any evidence of water. Also:
  • Removed the plastic air vent under the wipers and poured water down the windshield and into drain area and could not replicate it.
  • Lifted the plastic insert forward of the roof rail, flooded it with no luck.
  • Peeled back the fender liner to see where the water runs down from the drain area under the windshield and cannot see where it could be entering.
  • Not coming from the door seam as I watch from inside with it closed and water spraying on the side of the vehicle.
  • There is a fresh air vent behind the drain area with raised metal edges but water never makes it that far back when I flood it.
Any ideas as to where this water is entering?
Old Nov 7, 2021 | 05:51 PM
JillOfAllTrades's Avatar
Default Re: 2003 03 Odyssey Water Leaking Under Passenger Side Front Carpet
I have the same year Odyssey as you and have the same problem with water under the carpet on the passenger side. I also lifted up the rubber mat and it looked like the water was coming from under the mat. Likely running under the mat from somewhere above. I hadn't driven the van in awhile but there had been a couple of heavy thunderstorms come through that saturated the carpet. Did you ever find out what was the cause/where it was coming from?
Old Nov 8, 2021 | 05:53 AM
Jafatz's Avatar
Finally solved it about a year ago after peeling back the headliner and removing the passenger side A-pillar trim piece on the side. It was leaking from the windshield top right corner and running down the A pillar, then under the rubber matting that's behind the dashboard and floor and then seeping through the carpeting. Had the windshield replaced as the previous replacement had a lifetime warranty. When the windshield was removed there was section of sheet metal where the windshield was glued on that started to rust and separate from the seal. Dry as a bone since the replacement.
murdoko
Mar 27, 2016 09:05 AM
Creature1
Honda Civic (2001 - 2005)
May 5, 2014 10:13 AM
mcd7
Jan 21, 2012 11:33 AM
Slosc2
Apr 15, 2009 07:56 AM
biscuit01ex
Apr 30, 2006 11:20 PM
