Overheating/no fans
Old Oct 25, 2019 | 04:39 PM
bp86's Avatar
Default Overheating/no fans
So I replaced all the coolant sensors, switches, sending unit and thermostat and no luck. I'm stumpt. No leaks anywhere. Please help.
Old Oct 25, 2019 | 10:46 PM
Aradin's Avatar
Premium Member
Default Re: Overheating/no fans
Do either of the fans turn on with the AC running?
Old Oct 25, 2019 | 11:22 PM
bp86's Avatar
Nothing when heat or AC is on..
Old Nov 13, 2019 | 07:36 PM
BlueBomberTurbo's Avatar
Try checking the radiator fan control box under/behind the bottom of the glove box. It's a medium size black box that slides off the metal reinforcement of the bottom of the glove box, next the blue diagnostic plug. If it's unplugged (or broken), the radiator fans never come on.
Old Nov 13, 2019 | 08:40 PM
bp86's Avatar
Control box is good, fans turned on when jumping switch A.. ended up taking it into a shop.. supposedly I got counterfeit coolant switch sensors off eBay.. I'll never know for sure but the fans kick on at temp while driving now.. thru my DIY trials and errors, the temp and rpm gauges are shot now.. so I bought a bluetooth obd2 module and downloaded an app to monitor stuff.. got a CEL while trying to complete drive cycles, code P0401.. mother luv'n EGR insufficient flow.. once that's fixed, I can only hope to pass smog so I can register the damn thing so I can drive it off a cliff.
oregonaccord
Jul 4, 2011 05:21 AM
aquaman6650
Apr 9, 2011 08:13 PM
B18CYAAA
Jan 8, 2007 08:44 AM
89DXDann
Jun 10, 2004 01:42 PM
BoostedH23a1
Dec 14, 2002 02:40 PM
