Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Disassemble intake resonator?
Old Oct 25, 2019 | 06:34 AM
kaivorth's Avatar
Default Disassemble intake resonator?
Is there anyway to take apart the resonator? There's a bunch of acorns in it from freaking Chipmunks. Can't shake most of it out.
Plan on changing the air filter too
Old Oct 26, 2019 | 10:51 AM
kaivorth's Avatar
Default Re: Disassemble intake resonator?
Anybody? Can't seem to break the thing loose.
Old Oct 28, 2019 | 07:48 AM
NDNV's Avatar
This might help:
Old Oct 28, 2019 | 05:03 PM
hondandy's Avatar
The whole thing just pulls right out. I think it 10 mm bolts, once they are out the stuff lifts up and out. You can leave it off like I did or clean it all out and put it back on if you want it nice and quite. The only downside to leaving it off is the filter may need to be replaced more often.
Old Oct 28, 2019 | 05:40 PM
kaivorth's Avatar
I can take it out easily, but I'm wondering if you can disassemble the resonator itself. It looks like they're 2 halves to it. I want to clean it out. Lot of acorns in there a vacuum and a blower can't get out
Old Oct 29, 2019 | 04:15 AM
hondandy's Avatar
I think the 2 halves are stuck together. Like formed then pressed together while hot or even glued. I don't see why you can't shake it and have the acorns fall out.
rockenuptown
10
Jan 15, 2007 08:05 PM
texx
Jan 31, 2005 04:07 PM
5thgenlude101
Aug 28, 2003 01:43 PM
