Need new crank, OEM, Eagle or brian Crower?
Old Oct 25, 2019 | 04:45 AM
Tharshan's Avatar
Default Need new crank, OEM, Eagle or brian Crower?
Unfortunatly my crank got hurt badly when my flywheel got loose, so I need a new crank. But I cant decide if I should go for used oem, or a new eagle or brian crower crank.
It's a 97 civic with a sleeved b18c from benson with, cp 84mm pistons, pauter X rods, LS crank(89mm), arp mains and acl bearings. Turbo I'm running is gtx 3076r gen2 and I'm aiming for a 600-650whp. Car is daily driven and tracked, mainly for circuit racing. Im revving it to 9400rpm.
What would you recommend? I got in contact with realstreet and they told me that the BC crank is 4lbs lighter then oem and Eagle.
Everything will be rebalanced.
I would like a recommendation based on relaiability, power goal, rpm range, and the fact the car is both daily driven and used for heavy duty circuit racing.
Old Oct 25, 2019 | 05:00 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
Default Re: Need new crank, OEM, Eagle or brian Crower?
Stock crank with a balanced crank pulley . I shift at 9500 and I’m 650whp with CSS block 81.5
Old Oct 25, 2019 | 05:01 AM
Txdragon's Avatar
I'd go BC, provided it's within your budget.
Old Oct 25, 2019 | 08:15 AM
TheShodan's Avatar
Moderator
I'd find OEM, but they are harder to obtain as of late.
Old Oct 25, 2019 | 11:24 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
I suggest staying OE... it is forged and you can use OE bearings without modifying the edges because of the larger filet radius' found on the aftermarket crankshafts.
Strange World
Dec 26, 2012 12:29 AM
vipcivic
Dec 25, 2008 07:49 AM
sour97
Sep 30, 2007 05:05 PM
mec. pedri
Feb 25, 2006 05:26 PM
brnyrdcmndo
Jun 11, 2005 09:37 AM
