93 del sol s. K swap vs b swap
I bought a 93 del sol s with a d15b7 for the sole purpose of swapping it. It has manual steering an no a/c, and 5 speed manual transmission. I’m trying to make about 250-300 whp with a turbo eventually. Would it be more worth it to k swap or b swap? Also what would the cost be? I’ve searched around quite a bit but most of the posts I have found regarding cost are really old, like 5-10 years +
This car will not really be a daily but at least get driven a few times a week when I want something more fun to drive.
Also, I will be doing the work myself so don’t need to factor in labor costs.
Would like to keep the budget around 3-5k tops. I’m going to slowly piece the build together as I have the funds
You will not get to 300 wheel HP with a "K" series swap at your maximum budget, so great deals on "B" series parts is your only path.
I think you'll be doing good to get a stock b or k in your car for your budget. I'd focus on that for now and get it running right then save for turbo stuff later. Do a spreadsheet comparing the costs of purchasing engine, transmission, mounts, ecu, harness, etc.
