93-95 Civic Del Sol Part Out / 94 -01 Integra Suspension
Old Oct 23, 2019 | 07:46 PM
D15B7_EG1's Avatar
Default 93-95 Civic Del Sol Part Out / 94 -01 Integra Suspension
Hello,
I am parting out my 1993 Del Sol. I mostly have interior and suspension parts. All prices are OBO. NOTE: I still have to remove the Eibach Spring/Shock Combo, the sway bars and front/rear LCAs.
D-Series California Catalytic Converter - $250
JDM Type R 25 MM Front Sway Bar with end links - $180
JDM Type R 23 MM Rear Sway Bar with end links - $180
Tokiko Blues with Neuspeed Springs (Cut) - $80
Del Sol Climate Control **** - $30
Del Sol Seats in Used condition with no Rips - $200
EG6 SI Rear Sway Bar - $20
Rear Del Sol Glass Assembly - $80
Del Sol Floor Mats - SOLD
Rear Del Sol Storage Bin and Panels - $60
Del Sol Side Skirts - $20
Rear Del Sol Speaker Panels - $40
Del Sol Trunk Cardboard - $5
Del Sol Center Console and Storage Bin - $40
Stock Air Intake Arm - $40
D15B ECU - $20
Del Sol Dash - $100
Del Sol Gauge Cluster - $60
Eibach Spring and Shock Combo with Polyurethane Bushings - $300
Power Slot Rotors - $40
EBC Yellow Pads - $60
Integra Top Stabilizer Bar $5
D-Series Radiator - $20
Old Oct 27, 2019 | 07:50 AM
D15B7_EG1's Avatar
Default Re: 93-95 Civic Del Sol Part Out / 94 -01 Integra Suspension
PMs responded to. Shout-out to HT, glad to see it is still going!
Old Oct 27, 2019 | 03:08 PM
D15B7_EG1's Avatar
Wheels and floor mats are pending sale.
Old Nov 1, 2019 | 08:01 AM
D15B7_EG1's Avatar
Floormats are gone.
Old Nov 1, 2019 | 02:54 PM
2001GSR4DR's Avatar
Will these fit a 2001 GSR Sedan, with ITR spring/shock/LCA?
Old Nov 1, 2019 | 11:26 PM
D15B7_EG1's Avatar
I'll have to research it, but it should. Will let you know.
EDIT: In the process of pulling it out.
Old Nov 2, 2019 | 09:09 PM
born2lose's Avatar
will bolt on however you should consider a brace such as ASR or comptech. Some have experienced tearing in subframe because springs were too aggressive. ITR compared to gs-r have stronger subframes or maybe just extra braces that non ITR may not have. i have an ASR brace for sale, if interested.
Old Nov 2, 2019 | 09:40 PM
2001GSR4DR's Avatar
Received your pm that it will fit
can you clarify... after I figured out it will fit, I saw that bracing is needed, which put me off a bit
are you saying the ITR springs I have is aggressive, so I need a brace ? Or are you saying if I put the 24mm swaybar , I need the brace?
how much are you asking?
thanks
Old Nov 3, 2019 | 07:13 AM
D15B7_EG1's Avatar
thanks
I have the beaks kit and the endlinks for $180. I can shoot you a photo of the beaks kit which comes with the sway bar if you PM me your number.
Old Nov 3, 2019 | 07:15 AM
D15B7_EG1's Avatar
Yup, that's right.
Old Nov 3, 2019 | 12:55 PM
born2lose's Avatar
thanks
i don’t believe you need a brace with oem ITR springs but I will still use one just in case you want to upgrade or for extra security. Once your frame tears, you can’t go back. Pm me if you’re interested in the ASR brace.
darkenedsol
Northern California (Sales)
Jun 4, 2014 09:26 PM
Jakessw
Mar 24, 2010 08:25 AM
Xathine
Sep 25, 2009 02:50 PM
astroxtc
74
Oct 6, 2005 08:48 PM
mrnicolas
Sep 25, 2004 06:42 AM
