Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Maintenance light won’t reset after all fluid replaced
Old Oct 22, 2019 | 02:30 PM
Floopsoupn's Avatar
Default Maintenance light won’t reset after all fluid replaced
Hello, I’m currently having issue with getting my maintenance light to reset. I have a 2001 Honda Civic Ex that I’ve been fixing up. I’ve gotten a lot done but for some reason I can’t get the maintenance light to reset. I have an my oil changed and with that all the fluids topped off. I’m about to get the brakes done here soon. Could it be the brake fluid? It’s the only fluid I have yet to top off/change.
Thank you for all the help!!
Old Oct 22, 2019 | 03:13 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Maintenance light won’t reset after all fluid replaced
You may have to press on the reset button quite hard while holding it for the 10 seconds.
Old Oct 22, 2019 | 07:26 PM
Floopsoupn's Avatar
I’ve made that attempt multiple times and it continues to come up. Maybe shuts off for about 2 seconds then clicks right back on.
Old Oct 23, 2019 | 04:55 AM
NDNV's Avatar
I don't think I have ever read about the Maintenance Required indicator not being able to get reset.
Anyway, here is the process to reset it in case you are doing it incorrectly:IMPORTANT: The headlights and parking lights must be off before attempting the MAINT REQ'D light reset procedure. If the lights are on, the MAINT REQ'D light will not reset. If your Civic is equipped with daytime running lights (DRL), the DRL must be disabled so the MAINT REQ'D light can be reset.
These are the steps:
  1. Turn the ignition switch to the OFF position.
  2. Press and hold the SELECT/RESET button in the Gauge Cluster.
  3. While holding the button down, turn the ignition switch to the ON position (but without cranking or starting the engine).
  4. Hold the SELECT/RESET button for about 10 seconds.
  5. After 10 seconds, the MAINT REQ'D light will reset and turn off.
Old Oct 23, 2019 | 01:59 PM
Floopsoupn's Avatar
Thank you I never would have thought of the DRL. I attempted it again after verifying it was off and the maintenance light still clicked right back on after being off for a few seconds.
Old Oct 24, 2019 | 08:14 AM
NDNV's Avatar
Try this - "It was in odometer position. But, I again changed the cdometer position from odometer position to Trip A to Trip B and back to Odometer position and then repeated the process. This time it worked..."
Old Oct 24, 2019 | 08:18 AM
NDNV's Avatar
Try leaving headlights off and repeating the process.
Sometimes the push button in the gauge cluster craps out and needs to be repaired in the back of the cluster - hope this isn't the case.
ej6kid
Nov 1, 2010 06:55 PM
EFz6er
Jan 21, 2009 10:41 AM
LunchboxZT
Sep 8, 2006 01:22 PM
beau20
Jun 26, 2004 08:28 AM
mugen89
Aug 8, 2002 10:13 PM
