Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
honda accord 2007 i4 sedan with cxracing turbo kit
Old Oct 22, 2019 | 05:21 AM
hondafanornot's Avatar
Default honda accord 2007 i4 sedan with cxracing turbo kit
I bought cxracing tsx 04-08 turbo kit from cxracing, and instead using the turbo that came with it, i bought a precision turbo
fuel pump, 1000cc injectors, 2" exhaust with cat, and ktuner. No other mod. will update more info later.
feel free to comment because any is appreciated
Old Oct 24, 2019 | 07:56 PM
2003EX-LAccord's Avatar
Default Re: honda accord 2007 i4 sedan with cxracing turbo kit
Nice! What size turbo? What power are you making with this setup? I have a 2003 Accord Coupe with a 5 speed and I plan on either a S/C or turbo in a few years.
Old Oct 28, 2019 | 05:11 AM
4" turbo. I'm trying to "self-tune" first but with the basemap and some amateur adjustment, it's making 210hp at 10psi.
Old Nov 6, 2019 | 08:02 PM
Hidenplanvew's Avatar
I wouldn't mess with self tunes, take it to someone who knows what they are doing. How bad was the return line? What are your two feed lines?
Old Nov 7, 2019 | 11:48 AM
do you mean the oil feed? it came with turbo oil line kit, drilled a hole in oil pan and plug in adapter.
I picked the force induction option and flashed to ECU, I modified injector sizing, VTEC settings, still learning each parameter little by little. It runs much better than a V6 so i guess that's a plus.
Old Nov 18, 2019 | 04:49 AM
cmwright1986's Avatar
Only went with a 2” exhaust?
Old Apr 15, 2020 | 06:06 AM
after watching numerous people doing self-tuned, i learned and got to this point... will update if i mod it better
I also added a MagnaFlow 14832 exhaust.
I don't know why it's not giving a turbo lag or sudden boost like my friend's car but i'm happy with the linear acceleration.
Old Jul 6, 2020 | 10:04 PM
Marquis Turner's Avatar
is that a same side open to exit intercooler?
How did u get the turbo to mount so perfectly?
Old Jul 13, 2020 | 11:32 AM
yes.
The kit fits acura tsx and surprisingly it mounted perfect on my honda accord. thx God.
Old Jul 13, 2020 | 11:33 AM
I've put about 4k miles and no issue. Overall, i'm very happy. I could have and should have larger exhaust.
Old Jul 20, 2020 | 08:14 PM
CiGHonda's Avatar
First of all, you are crazy.
Second of all, this is awesome!
Looks clean, I would probably do a battery relocate to the rear and get the air intake into the front, but otherwise cool!
Old Jul 29, 2020 | 06:32 PM
Taylor Webster's Avatar
so exactly what year acura tsx was this kit for I want it
Old Apr 13, 2021 | 01:24 PM
dan brown's Avatar
Hi I've been following this build for a while now and I recently started my own build. Mine is the same year accord nothing done to it it has:
A Greddy turbo kit from an rsx
with a garrott ball bearing turbo
Hks bovSynapse wastegate set at 10lbs boostAnd a 2.5 inch straitpipe going to a twin loop muffler
I highly recommend a bigger exhaust because it allows the turbo to spool a little bit more and you would have more boost on the tip end. I Also read that smaller exhausts can often mess up the turbo seals because it chokes the turbocharher's exhaust flow. This is probably why the powerband is more linear. I would also would like to know how you did the selftune and some tips or tricks possibly. Thank you for this awesome fourm.
Old Jun 4, 2021 | 07:51 AM
From the ktuner, I selected the force induction map, then started changing the parameters. I attached it here so you can compare the original vs what I did. It was really trial and error tune so to tell you how I did it would be tough. Over time I kept making changes but nowhere I can possibly adjust the way I want it. I think I need larger exhaust pipe like you said.
File Type: zip
Old Jun 4, 2021 | 08:57 AM
By the way, if you upload your tune, I'd like to try it on my car.
Old Jun 4, 2021 | 09:02 AM
https://www.cxracing.com/TRB-KIT-K20-TSX-T04E-IC
Old Sep 21, 2021 | 11:54 AM
Finally put on dyno and fine tuned to @265HP, 12psi. Nice extra power. Overall the car run perfect without issue.
2007 honda accord i4 cxracing turbo kit and precision turbo
Old Dec 3, 2021 | 07:57 AM
accordk07's Avatar
Where did you tap your vacuum lines
Old Apr 10, 2022 | 06:19 PM
lcl8628's Avatar
Could you please send me the purchase link website? OEM number is, thank you!
Old Apr 14, 2022 | 08:03 AM
davet1604's Avatar
hey i was gonna do the same think with the that same kit but was wondering what fuel pump you used and how it fit?
Old Dec 1, 2023 | 09:19 PM
SlammedK24Sedan's Avatar
Dude I’m literally fixing to buy this kit and do this to my 07 SE HMU please if you can spare any more details even though it’s been forever lol.
Old Jan 22, 2024 | 04:03 PM
cohrq's Avatar
hey whats the names if the silicone coupler ?
Old May 10, 2024 | 10:23 PM
prince_Juju's Avatar
this is my first time putting a turbo in a car and I was wondering if you could link or just let me know what specific fuel injectors and other parts that didn’t come in the kit. I’m trying to price it out so I can start my build!
Old Feb 9, 2025 | 04:09 AM
Sandboy88's Avatar
Did you have modify the intercooler piping at all?
projectpat817
Mar 13, 2004 10:42 PM
jodesi
Nov 28, 2001 04:46 PM
