Honda CR-V & Element 2WD & 4WD Element & CR-V
Brake Caliper Pistons Overextended
Old Oct 21, 2019 | 07:29 AM
cot266's Avatar
Default Brake Caliper Pistons Overextended
So I went to change my brake pads on my 2011 CRV, and stupidly pushed the brake pedal when the calipers were off the rotor. I overextended the pistons. I struggled to get one of them in, but then it did, and started leaking brake fluid. The other one, I can't get in. Any thoughts whether I need to replace the calipers, get a rebuild kit, or if they'll be fine??? I see on other forums that calipers are cheap. Well they aren't here. $333 a piece.
Thanks in advance.
Old Oct 22, 2019 | 06:28 AM
canister's Avatar
5 Year Member
Default Re: Brake Caliper Pistons Overextended
Get a new caliper or a bone yard caliper. Compressing the seals correctly is a royal pain and no one rebuilds calipers anymore so if you need help you are on your own.
Old Oct 22, 2019 | 11:54 AM
RyanTM3's Avatar
If you didn't wreck them trying to reassemble, a shop (with an experienced mechanic) might be better equipped and experienced to reassemble them for you. I'd call around and ask.
talkJDM
Suspension & Brakes
Feb 8, 2010 08:36 AM
Fatcobra
Mar 27, 2007 11:45 AM
rollingCULTURE
17
Jan 23, 2006 09:52 AM
indyjones
May 5, 2004 12:01 PM
IC x Prince
Jul 1, 2002 07:35 AM
