Transmission & Drivetrain Gearboxes, Differentials, Clutches
Brand new clutch / flywheel slips bad
Old Oct 20, 2019 | 08:06 AM
JDM_ego2033's Avatar
5 Year Member
Default Brand new clutch / flywheel slips bad
I put a JDM B20b in my EK hatch and have a lightweight flywheel with a yonaka 6 puck clutch and pressure plate all brand new with my GSR transmission. I noticed it slips really bad in reverse and i hear banging under the hood if i dont get off the clutch or push it back in all the way quick enough. I almost feel like its the mounts for that but i never had an issue with them before. First gear also slips but im not on it as much as reverse. I also put a K tuned master and slave cylinder for the clutch. I checked the adjustment and it made the clutch pedal feel a little better but it slips just as much. the car even stalled in first twice and took a minute to start back up. Has anyone had these problems and what should i be checking cause im running out of ideas?
Old Oct 24, 2019 | 02:49 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Brand new clutch / flywheel slips bad
Why did you cheap out on a clutch+PP ?
Old Oct 24, 2019 | 08:53 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
If its slipping make sure that the clutch fork doesn’t have a bunch of preload on it. Sounds like a master/ slave issue more then a clutch issue as long as everything was clean when put together. I’ve ran tons of cheap clutches and they get the job done just fine for lower hp cars. This sounds like a problem you’ll need someone to look at in person more then having people online try to guess what the issue could be.
Old Oct 24, 2019 | 12:56 PM
5 Year Member
because why would i drop more money on a clutch to handle a stock b20b? im not using it for a turbo engine running 400hp or some **** this is a daily and just something to get it actually running. you've been a real help
Old Oct 24, 2019 | 12:57 PM
5 Year Member
i adjusted the pedal and it feels a little better. It grabs really high up and has a quick engagement point so im hoping maybe theres just still air in the lines. i really only notice it in reverse and sometimes in first its hard to get a good start but that could also just be because its new and im not used to it yet.
Old Oct 26, 2019 | 11:26 AM
Loved
Community Favorite
Yeah it will take some adjusting to learn how to drive it if your used to a stock clutch.
Old Oct 28, 2019 | 02:04 AM
NVturbo's Avatar
O.G. triple O.G.
you're welcome, CHEAPASS...
KiasSan
Jun 27, 2012 02:21 PM
cdees
19
Jan 7, 2010 09:15 AM
SOHC_MShue
Oct 9, 2008 05:19 PM
Chiller
Apr 10, 2005 10:52 PM
DriveSideWays
Feb 29, 2004 09:04 PM
