Blinking oil light, low oil level
Old Oct 17, 2019 | 09:35 AM
the_white_teg's Avatar
Default Blinking oil light, low oil level
I have a ‘96 gsr that has recently been tuned to get rid of a spark ping issue. Went on a road trip (~400 miles), got into vtec one time, and once I got back into town the oil light started flashing steadily. Drove it home, parked it, and the dipstick had no oil on it when I checked. No smoke, smell, or leak that I can see without putting it on a lift. Car runs and drives fine with no weird engine noises. Any ideas?
Old Oct 17, 2019 | 10:54 AM
BlackJack_DC2's Avatar
Default Re: Blinking oil light, low oil level
I think you need some oil
Old Oct 18, 2019 | 02:13 PM
wunfstgsr's Avatar
Loved
Community Favorite
When the oil light comes on it means low oil pressure which means you have literally no oil in it! the good thing is the oil pressure sensor is working! always! always! always!! check the oil in the morning before starting the engine! once you start the engine you wont get a accurate reading on the oil level on the dipstick. The Honda engines all eventually burn oil vtec or not. But if you keep an eye on the oil you should never run into this issue. And your lucky you didn't spin a rod bearing from having no oil! keep it toped off and check it daily!
TinoNT
Apr 26, 2013 01:34 AM
jlm728
20
Feb 1, 2009 07:33 AM
csambitions
Mar 20, 2006 09:42 AM
slg
Feb 9, 2006 05:40 PM
EFz6er
Dec 28, 2004 01:39 PM
