Getting to C563
Old Oct 16, 2019 | 11:27 AM
T Mst's Avatar
Default Getting to C563
I'm tracing down the reason my brake lights don't work and need to check connector C562. Here's the photo from the service manual, but for a sedan. Must the left rear interior quarter panel be removed to get at the connector on a '99 Civic EX coupe?
And here's the wiring harness diagram:
Connector c562 shown by left wheel well
Old Oct 23, 2019 | 03:25 PM
T Mst's Avatar
Default Re: Getting to C563
Anyone...?
Old Oct 23, 2019 | 08:34 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
I believe the answer is YES... but you could have already found this out by popping the panel and taking a look. From the trunk end, follow the wire bundle back toward the front of the car and see if the C562 20-pin Grey connector is visible before you get to the rear seat back... and if you do not, then it will be behind the 1/4 trim panel.
Old Oct 31, 2019 | 04:26 PM
T Mst's Avatar
Thanks. As I feared. I really wanted to avoid removing the back seat, which I believe is required in order to pop that interior panel.
Marvin1985
Apr 19, 2016 08:25 PM
GOLF BRO
Jan 16, 2015 10:57 PM
ACrite3404
Apr 25, 2008 08:48 AM
Nerologic
Nov 24, 2007 02:30 AM
