Where to find PTE V-band inlet Turbine housing for my 6266 JB?
Old Oct 13, 2019 | 06:18 AM
B_Swapped93's Avatar
Default Where to find PTE V-band inlet Turbine housing for my 6266 JB?
I know you get can the v-band inlet housing for the JB 6266 when you buy it new I did't select that option when i got mine as all the OTS sidewinders were t4/t3. I will be ordering the Prayoonto FWD/AWD manifold soon, and would like to be able to get it with the precision V-band inlet. However if i need to sell my whole turbo just to get the outlet it's iffy, i can't seem to find a solid source that i can just switch over to a V-band inlet. let alone a place that sells them for the JB version
Old Oct 13, 2019 | 09:49 AM
TheShodan's Avatar
Moderator
Default re: Where to find PTE V-band inlet Turbine housing for my 6266 JB?
You won't. You'll need to buy a separate turbine housing from Precision to do that. I always thought that PTE sold their turbine/compressor housing independently, but .
Trying to get one from another company would work if you knew of a place that could machine the exhaust wheel profile of PTE's turbine wheel. That's the trick.
Old Oct 13, 2019 | 02:21 PM
https://www.treadstoneperformance.co...rbine+Housings Treadstone appears to sell them but notes they ship directly from precsion, yet i can't see anywhere on their selling turbine housings. I assume i'm 66 trim? 62 being the compressor?
Old Oct 13, 2019 | 04:09 PM
TheShodan's Avatar
Moderator
no. trim is simply a measurement between the inducer/reducer of either a compressor or exhaust wheel. PTE goes by exducer of their exhaust wheel, which is 66mm (which DOES NOT denote the wheel diameter).
But it looks like of course Treadstone doesn't know that, so like most places they replace exducer with trim. so it's probably the right one. I personally would contact PTE with that part number shown there to confirm.
62 is the compressor wheel inducer measured in millimeters.
Mike_ef
Nov 23, 2013 10:24 PM
bunnyrabbit
Oct 24, 2005 10:00 PM
0ptimus prime
Feb 24, 2005 07:25 AM
kun3racer
Apr 11, 2004 06:53 PM
Type Wah
Jan 30, 2003 10:16 PM
