94 Acura Integra
I'm building a 94 Acura Integra LS for dirt track racing and I'm looking to put in aftermarket gauges. The dash is completely removed as well as the instrument cluster and want suggestions on what to get.. All I really need is oil pressure and engine temp.. Any help would be greatly appreciated
well they have aftermarket gauges for that and since those are the ONLY 2 gauges you need it shouldn't be much work other than running some wires through any of the available openings that you will have since the dash and everything behind it is stripped.
I apologize I wasn't clear.. Im inquiring to see what wires in the harness are for engine temp and oil pressure and can you splice into them from the harness that connects to the instrument cluster.. Or do you have to run wires to the engine bay?
smokerz212
Mar 9, 2006 03:23 PM
