99 integra LS Exhaust leak HELP
Old Oct 10, 2019 | 08:37 AM
cigges's Avatar
Default 99 integra LS Exhaust leak HELP
video if my car^
You can see the poorly made jerry rigged gasket as well, but i cant tell whats causing the smoke. The temp gauge also reads and stays below the middle line. Not sure whats wrong. Thanks.
Edit: (yes i see that the heat shield is off. I took it off to look.
Old Oct 10, 2019 | 09:38 AM
tony_2018's Avatar
Fish Twig
Default Re: 99 integra LS Exhaust leak HELP
Smoke doesn't mean you have an exhaust leak. I do see some oil leaks, wonder what else is leaking. That leak could be dripping onto a hot header and causing the smoke. GL.
Old Oct 10, 2019 | 10:31 AM
1990IntegraLS's Avatar
Smoking a bit? Could be residual. When was the last time the car ran. Before you changed anything?
Old Oct 10, 2019 | 11:34 AM
maxwellmercer's Avatar
This. oil is definitely coming down from above onto the header, causing the smoke. Clean up the motor and pin point your leaks!
Old Oct 11, 2019 | 05:11 AM
NoKz's Avatar
The outside of the oil pan is wetter than the seat of a middle-aged woman at the 50 shades of grey movie premier.
You have a leak somewhere that's dripping directly onto the header.
Check the following:
  • Distributor O-Ring
  • Valve Cover
  • Cam Shaft Seals
  • Oil Pan Gasket
  • Rear Main Seal
  • Main Seal
Old Oct 11, 2019 | 10:58 AM
Originally Posted by NoKz
....wetter than the seat of a middle-aged woman at the 50 shades of grey movie premier.
lovely image.....cringe
Old Oct 12, 2019 | 06:59 PM
wunfstgsr's Avatar
Loved
Community Favorite
You are burning oil on the header! looks like its the oil pan gasket..
dc2moi
Jul 1, 2008 12:51 PM
lakerschamp2000
Mar 7, 2005 04:58 AM
bccivic
Jul 29, 2003 11:39 PM
