acl race oil pump bad?
Old Oct 10, 2019 | 03:47 AM
Ryan Blair's Avatar
Icon5 acl race oil pump bad?
So on a previous post about my turbo gsr build I had a guy advise me on not using the acl race oil pump but I had already ordered one. When I received it in the mail I took it out to inspect. My first reaction was not good the gears seem to have a awful amount of play, enough to where I can put my fingers on the inside of the hole and move it left and right quickly and hear clacking and what feels like a gap between teeth. My oem pump with 220k miles is still smooth with no play. I spoke to the seller and he swears they are supposed to be like that. Says he builds Honda’s for a living and uses one on his,but I have talked to other builders and machinist that say there is no way they would use it. Has anyone else ran into this before?
Old Oct 10, 2019 | 05:58 AM
Txdragon's Avatar
Default Re: acl race oil pump bad?
Stick with OEM. Even Melling is hit or miss..
Old Oct 10, 2019 | 06:37 AM
AZ_CIVIC's Avatar
For all my builds I call up Acura and order a brand new one, put it on just the way it is and it supports plenty of power.
Old Oct 10, 2019 | 06:40 AM
Ryan Blair's Avatar
im going to go oem now just wondering if anyone else has ran into this with acl pumps before
Old Oct 10, 2019 | 06:43 AM
KiNGDEE206's Avatar
What’s with the increase in Oem oil pump price though :/
I use to see it on eBay for $130-140 shipped
now it’s 200 area :/ so sad
Worst part is I definitely bought one bnib left in garage/room > like 2 years ago and now I come to finish my build missing!
Sucks but still Oem!
Old Oct 10, 2019 | 08:01 AM
maxwellmercer's Avatar
I was told Honda is slowly weeding out all these, what I thought were, common B series maintenance parts. Prices are more than likely going up due to supply decreasing. I believe I just paid around $150 for a ITR one earlier this year.
Old Oct 10, 2019 | 08:37 AM
Chance EG's Avatar
^This. Eventually only aftermarket or remanufactured units will be available.
Old Oct 10, 2019 | 08:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Stick with the OEM pump. Stock up in case they get disco'd.
Old Dec 31, 2020 | 12:29 PM
Sammyy's Avatar
Hi, I would “ONLY” use the original oil pump that comes with your vehicle & buy with it the Toda racing oil pump gear 84mm 15131-B16-000, & the Toda racing timing belt 06141-B16-000.
I installed these two parts back in 2005 & are still working strong. I was heavily involved in motor racing for 24 years & not once did I have an issue using these Toda parts in my B16a
Make sure you find a technically minded engineer to build your engine properly.
Circuit Star-29
May 5, 2006 09:40 PM
mahatma
May 4, 2006 08:38 PM
2uy
Oct 23, 2005 09:56 AM
OaksRacing
Oct 8, 2005 09:52 AM
sk8rmike
Sep 9, 2003 09:27 PM
