Oem hardline mated to russel -3 stainless braided line brake fluid leaks!
Hi I’m leaking bad
setup:
97 ex civic abs wilwood brake caliper -3 am fitting lines mated to the Oem hardline
so I tighten and it is really tightened the Oem hardline mated to brand new russel -3an brake line mated into my wilwood caliper
passenger side is leaking where hardline meets stainless steel line it’s leaking through the sleeve
it looks from my observation the stainless sleeve line isn’t making a seal with the hardline thus pushing fluid through to the sleeve
it’s raking exactly where my finger points
hsrdline>ss line> sleeve*** this is where it’s leaking****
my driver side isn’t leaking at all just passenger now so I fix?
