What Timing Belt for JDM D15B SOHC (non VTEC)???
I purchased a JDM 1992-1999 Honda Civic (non VTEC) Engine 1.5L OB2 Engine (has D15B stamped on the block) to put into my 1995 Civic DX Hatchback (replacing the D15B7 engine, SOHC 1.5L. What timing belt should I purchase? Will a timing belt for a D15B7 fit the JDM D15B?
The non vtec D15B JDM motor should use the same 106 tooth belt of the D15B7.
If it seems a touch loose, swap the timing belt tensioner from your dead D15B7 onto the JDM D15B and that should take up the touch of slack.
Boostage
Jun 10, 2007 09:12 PM
crx si 2004
Feb 8, 2005 07:52 PM
