Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Long crank !!
Old Oct 9, 2019 | 05:06 AM
Pedro Rubio's Avatar
Default Long crank !!
My em2 has been having a long crank lately, I installed new battery , new crank sensor. It cranks for like 5 seconds then starts some times it don’t start till second key cycle. Does anyone know any ideas. I was thinking maybe clogged fuel pump filter ??
Old Oct 11, 2019 | 05:23 AM
civichxtreme2's Avatar
Default Re: Long crank !!
Id check fuel delivery, pump may be on the way out or the filter may be clogged as you suggested.
Old Oct 13, 2019 | 06:56 AM
benchwarmer's Avatar
5 Year Member
I had low fuel pressure on an 04 civic , I replaced the pump unit only installing it into the original assembly , I still had intermittent problems for a short time , if they continued I would check all the wiring in the assembly , then I find the entire thing , plug and play , can be bought on line for about $80** , if I hadn't already bought the pump unit that would be a reasonable choice .
SeanRK
Honda CR-V & Element
Dec 8, 2015 04:12 PM
aemintgsr
Nov 6, 2010 08:04 AM
jackstands
Mar 13, 2005 08:54 AM
