Timing and accessory belts
Old Oct 6, 2019 | 11:21 AM
DongBilzerian's Avatar
Default Timing and accessory belts
So dealing with that god awful crank bolt I managed to spin the crankshaft off of TDC dealing with it. The camshaft stayed TDC the whole time. I set the crank back to TDC and reassembled everything. My first question is, I replaced the water pump and upon first start it ran fine for a minute or two and then made some weird hollow like howling noise for 2 straight minutes that I literally could not track down and it went away. The entire time the sound was happening the car idled fine and I can’t reproduce the sound, could it be from the cooling system running dry since the block drained when I removed the pump? The issue I’m left with now is after driving for 10 minutes the accessory belts are screeching. And they only do it in a drive gear not in neutral or park and the screeching only begins when the brakes are depressed and then continues until the car is in park or neutral... any ideas?!?
C3nturion
Honda Civic (2006 - 2015)
Oct 7, 2024 11:10 AM
89lsteg
Jul 10, 2011 10:18 AM
Acidcrakker
Oct 30, 2007 04:23 PM
tdizz07
Feb 27, 2006 01:35 PM
Danbu$
Nov 14, 2003 06:15 PM
