Humming sound at speeds more than 30 mph...
Hi all-
I have a 2015 Honda CRV, and recently it began making this type of higher-pitched "humming" noise, very noticeable on highway... usually at speeds more than 30 mph. Any ideas?
Here is a short clip of the sound:
Thank you very much for any insight,
Keith
Keith
Have 23K miles on the car so pretty shocked on this being the cause. Fortunately, they had the part in stock and were able to repair it under factory warranty.
I did have the tires checked to rule them out first.
Something else it could be if it is an AWD is the drive shaft to the rear axle, u joints center bearing that sort of thing. And the rear axles as well has its fluid been changed recently?
