Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2001 Odyssey no running lights or instrument lighting
Old Oct 3, 2019 | 01:48 PM
amvmr's Avatar
Default 2001 Odyssey no running lights or instrument lighting
2001 Odyssey no running lights but brake and turn signals work.
No instrument light but all gauges working.
The red door open indicator in the instrument panel does not work for the passenger side sliding door.
Door works fine and red open door indicator works fine for all other doors.
Source code scanners, application scanners and system scanners all fall into a single category of scanner called which of the following answers?
Thanks
Old Oct 3, 2019 | 03:14 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 2001 Odyssey no running lights or instrument lighting
Anything done recently, like installing an aftermarket radio?
If not, check passenger side under-dash box Fuse No. 10 (15A).
Old Oct 3, 2019 | 05:12 PM
amvmr's Avatar
Fuses ok. I did tow a boat recently so maybe the trailer connection?
Old Oct 4, 2019 | 05:26 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Then it may be caused by a short from the trailer wiring. Examine the wiring for the trailer lighting connector.
Old Oct 4, 2019 | 02:52 PM
amvmr's Avatar
Everything is there as in your photo. I unplugged the connector and swapped the relays but no change. Is there a test I can perform here?
What would be the next step upstream. I am not really an optimist.
Old Oct 4, 2019 | 03:14 PM
amvmr's Avatar
Solved Ok forget all that above you were right the first time. It was the 15A fuse #10. Wow Honda's are great cars.
I didn't realize there are fuses on the passenger side so I was looking on the drives side.
True you were perfectly clear pointing me to the passenger side and I should have just followed your instructions.
Thanks very much for all your help.
Old Oct 4, 2019 | 03:19 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Glad you found out it was the fuse.
EMartin
Oct 1, 2019 08:58 AM
Tc72
Jan 23, 2007 03:21 PM
taney
Honda Civic (2006 - 2015)
Jan 19, 2007 10:11 PM
