What is the "BEST" BOV for 1000+whp?
Tial Q or Turbosmart Race Port
You can argue the merits & downsides of having A) No BOV, B) Small BOV C) Large or dual BOV. There isn't really consensus.
Your biggest factor is choosing something can handle the pressure of your turbo system - as this is H-T I'm assuming Honda 4 cyl platform and thus 45+ psi.
but you actually need one because with the amount of pressure you're using AZ, you'll cause horrible reversion to.the turbocharger, shortening its life.
many over the 1200whp mark actually use a wastegate as a BOV because it can. handle much more pressure than 50-70psi depending upon the setup.
Yeah, Locash wasn’t using one on his setup but told me it would shorten the turbos life, he was okay with that, I wasn’t so I kept it.
