D16z6 piston rings
Old Oct 2, 2019 | 10:18 AM
Chriseh9's Avatar
Default D16z6 piston rings
Long story short I’m doing an oem stock motor rebuild from the bottom up and the only thing i need that I’ve come across so far that’s discontinued are the piston rings. Does anyone know what the best aftermarket ring are that will give me the best fitment(ring end gap) and quality materials?
Old Oct 2, 2019 | 11:15 AM
tony_2018's Avatar
Fish Twig
Default Re: D16z6 piston rings
nippon?
Old Oct 2, 2019 | 12:40 PM
Chriseh9's Avatar
Originally Posted by tony_2018
nippon?
I know they make good pistons I just heard the rings aren’t that great and end gap can be An issue but again I have no experience with them
Old Oct 2, 2019 | 02:10 PM
NVturbo's Avatar
O.G. triple O.G.
so you're planning to put back the stock pistons? Why not just get a cheap set of YCPs and call it a day?
Old Oct 2, 2019 | 02:45 PM
tony_2018's Avatar
Fish Twig
You Can Pew
Old Oct 3, 2019 | 03:49 AM
mk378's Avatar
The ring gap check primarily an indication of cylinder wear. Take one of the old rings and measure the gap at the top vs the bottom of a cylinder. If there is a big difference you should have the cylinders bored and use oversize pistons and rings.
Old Oct 3, 2019 | 05:24 AM
K20.ek's Avatar
Any set of rings you get I would lightly sand the edges and end gaps with 2000grit in case of burrs on the edges. You wouldn’t want to install and run it in a fresh hone job then have it scarred up. Just a piece of mind imo.
Old Oct 3, 2019 | 09:45 AM
Chriseh9's Avatar
Thank you I had it honed and looks like it’s going oversized
Old Oct 4, 2019 | 07:07 AM
DaX's Avatar
DaX
Loved
Community Favorite
It may just be better to have it bored to 75.5 mm and run new pistons and rings. I've had luck (so far) with the Evergreen brand pistons and rings (on Amazon) on a stock rebuild.
mibayaua
Nov 6, 2012 07:34 PM
Wheelman-CZ
Feb 5, 2007 08:44 AM
TurboTeG4
Jul 26, 2003 01:39 AM
