2009 Honda Accord Door ajar, dome lights stay on if light switch set to door
Have a 2009 Honda accord ex special edition and the door ajar lights come on while driving which make the dome lights come on. Also if I'm sitting in car while it is running I can't locked the doors with the switch. I believe because this light is on please help. Thank you.
Re: 2009 Honda Accord Door ajar, dome lights stay on if light switch set to door
Probably a problem with the door switch. Whichever door that is indicated as open, exam the door switch. Open the door, in the door jamb on the car body is a door switch covered by a black rubber grommet. Press the switch several times to see if there is a change in the interior lights. It may either be stuck or may be faulty. It is easy to replace.
If it needs replacement, you can pry the rubber cap off with your fingertip, then remove screw and unplug wire. Install is reverse of removal.
