2001 Prelude H23 Bluetop swap/ Need ECU help plz
Old Sep 28, 2019 | 10:10 PM
Eg93si2's Avatar
Default 2001 Prelude H23 Bluetop swap/ Need ECU help plz
So I bought a 2001 Prelude with an H23a bluetop engine swap and the car itself was converted from automatic to manual. The check engine light has always ran simple codes but now I have new exhaust and the slight misfire is very noticeable now. The only ECU's I can find are automatic though, and ive heard that they can be changed. Is this true? If so, how? Thank you in advance.
Old Sep 29, 2019 | 10:27 AM
TimiK's Avatar
10 Year Member
Default Re: 2001 Prelude H23 Bluetop swap/ Need ECU help plz
H22A4 - H23 VTEC swap:
Originally Posted by Prelude1897
I hope you still have your original H22A4 ecu. Here's a list of what you needed to swap from your old motor to this motor in order to keep it all as if it came in the car factory
-intake manifold
-dizzy
-ignition coil
-oil pump
-crank sensors
-motor harness
No need for any extra wiring or special ecu. If you swapped these parts over, car would run normal.
Another option is chipped ecu + tune (or hondata)
Old Jan 15, 2020 | 07:42 PM
N2O_H23's Avatar
I have a 98 with h23 swap. I run a P28 with sst chip and Rich Tune Motorsports flashed a map for me
preludermengil
Jan 8, 2015 12:57 PM
natejones75
11
Oct 27, 2014 08:54 AM
ericstambaugh07
Jun 23, 2007 07:07 AM
darockstar
Mar 10, 2006 06:15 AM
h2392si
13
Jul 15, 2003 09:47 PM
