Question on power wire to fuel injectors on 1995 Accord
I was able to get my 1995 Accord running (thanks, for those who helped). The last issue I can’t seem to resolve is the 12v signal going to the fuel injectors. I’ve traced it to no power on the yellow/black stripped wire going into the injector resistor box. I’ve tried two different ECUs and same issue so it’s not the computer. Does anyone know where this wire leads to?
As a temporary fix, I ran a wire direct from the main relay to the resistor and it started right up and no but I don’t think this is a good as a long term solution. Any help is much appreciated. I’m attaching a picture for reference of which yellow wire I’m referring to.
Re: Question on power wire to fuel injectors on 1995 Accord
Originally Posted by tech8
The Yel/Blk wire power comes from the main relay via a junction connector.
where is the junction connector located? Also, does that mean how I have it ran now is ok? I have it tapped into there the two yellow/black wires are coming out of the main relay.
The junction connector is a 20P connector (can be orange or white) located behind the driver's side dash. If the Yel/Blk wire is being fed power via the same power source from the main relay, then yes it should be okay and function similar to if it was connected via the junction connector.
