Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Reading SRS Codes
Old Sep 25, 2019 | 09:25 AM
dphnd's Avatar
Default Reading SRS Codes
Hey guys,
On my 2008 Accord EX-L (4cyl):
Recently, the dashboard indicator began staying illuminated after the initial power-on lamp test.
I wanted to understand what the problem is before I take it to a dealer. I don't own an diagnostic computer capable of interpreting SRS codes, so I jumpered pins 9 and 4 on the OBD connector, and turned on the vehicle. The Airbag light shows no code, although I am seeing codes on both the TPMS and ABS lamps. (ABS lamp indicating code 6-1)
Questions:
  • Is it normal that the Airbag light shows no code even though it is illuminated during normal use?
  • Is there a process to retrieve the SRS failure code without a diagnostic computer capable of interpreting SRS codes?
  • I am capable of hand-entering OBD commands. Is there a command I can use to retrieve the SRS code (which I might then compare against a table of codes)?
Thanks,
forward
Jun 25, 2014 09:05 PM
eg_boi
Aug 4, 2008 01:12 PM
Cozmo Kraemer
Feb 17, 2003 12:26 PM
