What ECU can i use to replace my fried P08
Old Sep 22, 2019 | 02:33 AM
grimhold's Avatar
Default What ECU can i use to replace my fried P08
hi guys need some help. I'm not very familiar with ECUs. I have a 1994 Honda Civic 1.6 liter SOHC non-vtec automatic transmission. It's PH16 (philippines) which i believe is based on a D16 JDM.
The label on my current ECU shows 37820-P08-N51. The problem is that it's fried beyond repair and P08s that are in good condition are quite rare in the used ECU market here while other ECUs such as P06s, P27s, P28s are more common.
Question is...what alternative ECU model can i replace my P08 on a straight swap basis without the need for rechipping, reprogramming or change of harness?
Recently a guy had offered me a P75 with an OBD1 socket and he said it may work on my car. I'm a bit skeptical because i understand the P75 comes from Integras. Any thoughts?
thanks very much
Old Sep 22, 2019 | 05:41 AM
Chrisfrom1986's Avatar
Default Re: What ECU can i use to replace my fried P08
You have an automatic transmission so you MUST find an ecu that matches both the engine and automatic transmission as a pair.
GT500FTW
Nov 5, 2012 09:57 AM
Nooch
Nov 11, 2011 03:27 PM
faxshatch
Mar 18, 2008 05:08 PM
mrx
Mar 28, 2005 05:56 AM
TurboJesse
Jan 29, 2003 05:30 AM
