Tie Rods?
Old Sep 18, 2019 | 06:36 PM
alamz2's Avatar
Default Tie Rods?
I am wondering if my tie rods need replacing or if the problem was just that my tire was unbalanced.
I noticed a rhythmic clicking noise, which a couple of days later was found to be associated with my steering wheel shaking a bit as well, in sync with the clicking noise.
I rotated the tires and the clicking noise and the steering wheel shaking is gone. I also noticed that one of the tires is worn on the inside (driver side). I also noticed that the passenger front wheel can be moved a little bit with my hands, and I also noticed this loose piece. I have attached videos of these things. I will get an alignment, but do I need to replace the tie rods? If so, do I just replace all four or just the one in the video? That is the outer tie rod, right? Video links below. Thank you!
Wheel
Tie Rod?
Old Sep 19, 2019 | 08:07 AM
1990IntegraLS's Avatar
Default Re: Tie Rods?
If you're going to replace any tie-rods, do that before the alignment.
Old Sep 19, 2019 | 08:33 AM
jdmark1's Avatar
Your links didn't work for me unfortunately, but if you can wiggle the wheel left/right by hand then you should replace all the inner/outer tie rods. Also, the clicking noise is usually indicative of bad cv joints so inspect those as well. Replace the tie rods before you get an alignment and while you're at it, I'd also replace the upper/lower ball joints as well just to freshen things up. If they're worn like your tie rods then you'll notice a big difference in driving after you get your alignment.
Old Sep 19, 2019 | 04:13 PM
alamz2's Avatar
Could you try to see if the links work now, please?
I had both axles replaced recently because of a clicking noise with turning, but this clicking noise resolved after I rotated the tires.
Old Sep 20, 2019 | 01:10 PM
thewrai6th's Avatar
Your tie rods bushings are shot. From your description, it's also possible you have a bad axle or wheel bearing. I agree this should be fixed before any alignment.
Old Sep 22, 2019 | 07:33 PM
alamz2's Avatar
Does a wheel bearing require alignment after? Was thinking about getting tie rods and bushings replaced then get an alignment, and maybe wheel bearing later if needed
Old Sep 22, 2019 | 08:27 PM
wunfstgsr's Avatar
Loved
Community Favorite
A worn out tire from camber wear or a flat spot on the tire can cause shaking.
wunfstgsr's Avatar
Loved
Community Favorite
Wheel bearing No, tie rods Yes.
spoon.ef9
11
Jan 12, 2012 07:40 PM
bark3rk20
Suspension & Brakes
Jun 30, 2011 05:32 PM
Prelude Down
Apr 2, 2009 08:18 AM
Tuesday Club
Suspension & Brakes
20
Aug 20, 2006 12:20 PM
LSegHatchy
Oct 24, 2005 06:51 PM
