97 civic tie rods
Old Sep 14, 2019 | 08:22 PM
robertprante's Avatar
Default 97 civic tie rods
So I just replaced inner and out tie rides on the civic and it still drives like I never even changed them
Old Sep 16, 2019 | 09:09 AM
hondamark35's Avatar
Default Re: 97 civic tie rods
how did you know they were worn? just driving feel or did you check them by hand?
Old Sep 16, 2019 | 10:00 PM
Both, I checked them and then I had our mechanic at work check them. Driver side had about a 1/4 inch of play in it
Old Sep 17, 2019 | 05:04 AM
the play was gone when you rechecked after install, consider checking the adjustment on the rack guide. also double check the universal joint/coupler between the steering column and the rack.
Old Sep 17, 2019 | 10:01 PM
Yes the slack is gone, there is no play at all, so im thinking I need my tires balanced
Old Sep 18, 2019 | 02:58 PM
egsleepercivic's Avatar
describe the symptoms you are having a little better
also did you get an alignment afterwards ?
Old Sep 18, 2019 | 10:57 PM
no I have not got an alignment yet, but the symptoms are a very bad vibration from 50 mph on up, then the other day when it was raining my car was acting like it was hydroplaning but there was not water puddling on the roads just wet
Juan Bravo
Aug 30, 2019 05:50 AM
