Helicoil Tap size for tranny bolts h22
Old Sep 14, 2019 | 04:50 PM
Malt-liquor's Avatar
Default Helicoil Tap size for tranny bolts h22
I got 2 stripped bolt holes on my H22 block to where the tranny bolts in. I ordered the Perma Coil 106-612 M12 1.25 helicoil inserts. I drilled the holes out with the 31/64 drill it said on the package. I can't find what size tap I need for the helicoils. I've never done these before if anyone here has experience with these please help me out!
Thanks
Old Sep 15, 2019 | 01:15 PM
Ryanthegreat1's Avatar
Default Re: Helicoil Tap size for tranny bolts h22
Helicoil kit should have come with the tap. They are not standard tap sizes.
Old Sep 15, 2019 | 01:38 PM
Nope it came with 6 helicoils no tap.
Old Sep 15, 2019 | 04:31 PM
That is because you purchased just the inserts and not the install kit that comes with inserts.
https://www.threadkits.com/perma-coi...kit/3221-m12f/
Old Sep 15, 2019 | 04:56 PM
Ok thank you, went to 3 stores looking for a m12 1.25 tap fml..
viet_tec
Mar 21, 2008 03:16 PM
Marcpb443
Oct 2, 2006 02:12 PM
pinecone
Jul 25, 2006 06:37 AM
