92 civic code 41 problems
Old Sep 14, 2019 | 03:00 AM
RobertoHdz's Avatar
Default 92 civic code 41 problems
So I have a 92 civic si and I was having troubles with my car it was running sluggish and what not code 41 would pull up swapped the O2 sensor but code would not go away. Finally a buddy of mine suggested to swap my ecu with his, same ecu that goes in mine (p28) but his is in a del sol, his car runs great no problems no CEL. Swapped it car runs 100 times better but it's still throwing code 41 looked at the sensor looks good and wires. Any ideas?
Old Sep 14, 2019 | 02:58 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 92 civic code 41 problems
O2 heater fuse.
Old Sep 14, 2019 | 09:42 PM
egsleepercivic's Avatar
if a ecu fixed the cel, pop the cover and look for bad capacitors \ resistors on yours.
the original ecu is 27 years old at this point the electronics don't last forever
Old Sep 20, 2019 | 01:24 PM
RobertoHdz's Avatar
The CEL is still on but it the CEL doesn't come on in my buddies car with the same ECU
924doorEG
Jun 21, 2009 05:38 PM
LS AzZkIkr
Apr 9, 2007 08:01 AM
scarface50370
Dec 14, 2005 01:21 AM
Combustion Contraption
Jun 13, 2004 10:20 PM
