Where is the Starter Cut Out Relay on a 95 Civic EX sedan
I cannot find the Starter Cut Out Relay on a 95 Civic EX sedan.
My starter will not crank over with the key and I do not have 12V at the starter solenoid connector at the starter.
I can jump start it or push start it but it will not start with the key.
Please help!
Please help!
Sounds like it could be this problem: https://honda-tech.com/forums/honda-...start-2961138/
Worth a check at least.
If you're still determined to find the relay, it's up high in the driver's footwell against the side of the car, ahead of the door. But they rarely go bad. Likely some other issue.
yep those things are the right age to be toast.
check the floor for the broken parts.
just did all mine not too long ago.
.b20coupe.
25
Mar 5, 2016 05:26 PM
