Honda Ruckus and Scooters Ruckus, Silverwing, Reflex, Helix, Metropolitan
Ruckus won't start! Help!
Old Sep 11, 2019 | 06:55 PM
Josh Stair's Avatar
Default Ruckus won't start! Help!
Hey yall, so I have a 2015 ruck that won't start. The mods that are done are:
re jetted carb
removed stock air filter
aftermarket exhaust
changed weights in variator
switched out my handlebars and removed speedometer
i had issues with it starting, so I changed the battery. It then started having issues starting again. The ruck would also sputter a lot when going slow on initial start up then cut off. Currently I attempt to start ruckus and just get clicking sound. I tried replacing the spark but that wasn't it.
Any ideas on what it could be?
Thanks,
Josh
Old Sep 12, 2019 | 02:42 PM
sTol2m's Avatar
Default Re: Ruckus won't start! Help!
Will it start if you use the kick starter?
Old Sep 15, 2019 | 03:34 PM
Josh Stair's Avatar
No no it won't start with the Kickstarter.
Old Sep 23, 2019 | 07:20 AM
sTol2m's Avatar
It could be the battery needs to be charged, or the starter relay(square blue box underneath the positive terminal).
What type of air filter are you using in place of the stock filter?
The 'snorkel' hose is still needed even with an aftermarket air filter. It's not recommended to put the filter directly onto the carb.
This can be causing the hard start and sputtering issues.
Old Sep 23, 2019 | 12:30 PM
rchid's Avatar
Have you thought of resetting the ECU?
Old Dec 20, 2019 | 03:29 PM
CodyB83's Avatar
Yeah it's ecu related 99%
Old Jan 7, 2020 | 05:25 PM
rchid's Avatar
are you getting any spark from the plug?
97hatch904
Aug 31, 2015 04:38 PM
mister.wong
Sep 13, 2008 04:45 PM
lowblazin
Nov 25, 2003 10:00 AM
